  1. I'm sure this has been asked before, so please excuse me. I exported a Flash file to AVI and chose the Indeo 3.2 codec for compression. I then used TMPGEnc 2.0 to encode to MPEG. Ifollowed these settings:
    Video:
    352x240, 29.97 fps,1150 kbps
    Audio:
    44khz stereo, MPEG1-Layer 2, 224kbps
    Yet when I drag the MPEG into Nero to burn, I get the dreaded non-compliance message:
    "The following problems were found:
    'Stream encoding which is invalid for a(S)VCD.'"
    Ignoring the message doesn't burn the disc properly and re-encoding it makes it look like s#*t. Any ideas? Should I export the AVI from Flash as uncompressed? Thanks!
  2. Member Dhruv's Avatar
    Aug 2001
    Australia
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Yes, that should do the trick!
    I only dream in black & white...
    MSN: paschendale@gmail.com
  3. Ugh! That didn't work either. I've tried uncompressed as well as four different codecs, all with the same result. . Maybe it has something to do with Flash exporting it at 12fps? Or maybe the original dimensions (1024x76? I've also tried exporting it at various dimensions: 640x480, 352x240, 352x264. Ugh! The project was originally intended for a Flash screen saver (default Flash frame rate is 12fps). I'm at my wit's end!
  4. Oh boy. It looks to be a problem with TMPGEnc2. I just tried to drag an MPEG file (NOT exported from Flash and encoded in TMPGEnc2) into Nero and got the same message. I even re-installed Nero 5.5.4. I had converted this same AVI file in TMPGEnc two weeks ago and had encountered no problems in Nero. Is there a flawless (relatively speaking) encoder out there? I'll pay. I can't afford to lose this much time!
    <font size=-1>[ This Message was edited by: digitalhecht on 2001-10-20 14:59:11 ]</font>
  5. Have you tried resetting the frame rate to 29.97 in your Flash Export? I did this a while back and output to uncompressed video and it worked fine.
    Maybe your data rates and audio settings are the problem?
    Mike Mitchell
    Houston, Texas
  6. Thanks to all who have replied. I HAVE discovered that Flash is not the problem. It has something to do with Nero and TMPGEnc. AVIs that I converted with TMPEnc and burned with Nero last week, won't work this week. Nero keeps telling me it's a stream problem despite all the settings in TMPGEnc being correct. I HAVE discovered that if I use TMPGEnc to encode, and VCDImager Easy to burn, the VIDEO comes out great! BUT the audio plays back in bits and pieces. (It looks like I am not the only one who has this kind of problem with TMPGEnc: http://www.vcdhelp.com/phpBB/viewtopic.php?topic=63817&forum=3)
