I need to convert an AC3 audio file from 25 fps to 29 fps....I am trying to use Besweet, however, it will not work due to the fact that it seems like it no longer supports AC3 audio decoding (due to the fact of ac3enc.dll sucking!).
Why?
Every guide suggests that Besweet is the best for this, but it does not support it...yes, I have tried several different versions v1.5, v1.4....
Can some one please point me in a direction of a Besweet that works correctly?
or can tell me the command line in ffmpeg that will also do the convesion that I require (since they use the same conversion program)?
or point me in the direction of a better program?
Thanks...
Are you trying to change the playback speed of your AC3 audio?...or change the delay of the AC3 audio?
If you want to change the playback speed of your AC3 audio, I suppose you would need to decode to .wav and edit speed of the .wav with Audacity, Goldwave or something similar.
To change the delay, look in the tools section of this website.
See the audio encoding tools:
https://www.videohelp.com/tools?section=10#10
So frustrated! DVD Rips -> [anything] with Quick Sync = choppy.. sometimes
By s_mack in forum Video ConversionReplies: 39Last Post: 7th Jan 2012, 21:32 -
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 21:34 -
Frustrated Sony HDR-SR12 Owner
By jehill in forum Newbie / General discussionsReplies: 20Last Post: 5th Jul 2009, 04:54 -
Frustrated and Lost ! All I need is a simple menu for VOB files
By vulcan_man in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 06:12 -
frustrated with VDMOD and MSU sub remover
By volam in forum SubtitleReplies: 1Last Post: 7th Feb 2008, 09:45
