Well. I used to have no problems with TMP but lately
Firstly, I'm getting the 'ntblah.dll' crash all the time. No worries, thinks I, I up the priority of the DirectShow filter.
Now, it works fine - but insists that EVERY file I use as input is 30 fps!!!
Of course, editing the file is pointless because now instead of have 80,000 frames it has 120,000 frames & nothing is in sync!
HELP! I'm seriously considering ways to NOT use TMP any moreOf course, I have uninstalled & reinstalled it ...
Use G-Spot or VirtualDub to tell you the true framerate of the file. Even though you see more frames, they aren't there. Just set the framerate to whatever G-Spot or VirtualDub tell you. You will see that when the encoder actually starts the encoding, it will have the correct number of frames. Furthermore, only increase the DirectShow filter when you get crashes or the like with the particular video. Otherwise, keep it set at the recommended setting.
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 07:59 -
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 13:43 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Annoying blackscreen problem with AVS video editor
By in flames in forum Newbie / General discussionsReplies: 0Last Post: 4th Dec 2007, 23:10
