Hi,
i guess the subject says it all,
i do 3d animations with 3ds max 6,
for dvd output, i want the best quality possible,
i've tried uncompressed video but it is too big,
and hard to work with it, i've heard that dv video
would be the best, is this true?
because i tried it and the image is good but no dvd movie quality,
please let me know the best way to achieve dvd movie quality.
Thanks.
Invest in a very large HD. I too animate with 3ds max and maya, and if you want DVD quality, it is best to render to a sequence of Targa files and then use video post to output them to an avi.
then, take this (enormous) avi, and render to MPEG2 with any of the following:
TMPGEnc, CCE, MC QT Pro (if you are a mac user too) etc.
hope this helps. -
you can save yourself a step (and some room) there drewson99
1. render max stuff to targas
2. load targa seq. into v-dub mod
3. frame serve from v-dub to encoder of choice ...
but otherwise what drewson99 says is correct -- the best way ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
nice - you are right, and I would do it if only I was allowed to install Vdub on my PC at school (long story about how we lost the right to do that)
but when I start working at home, you will have saved me a step.
-A
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 13:53 -
3DS Max vs Maya vs Cinema 4D
By surferadi96 in forum EditingReplies: 7Last Post: 12th Feb 2012, 16:13 -
Help with importing tracking data from Boujou to 3DS Max.
By surferadi96 in forum EditingReplies: 3Last Post: 11th Feb 2012, 09:30 -
which is the fastest encoder no matter output format
By gyzel01 in forum Video ConversionReplies: 30Last Post: 17th Nov 2011, 04:20 -
output resolution xilisoft video encoder
By KlintIstwood in forum Blu-ray RippingReplies: 2Last Post: 20th Dec 2008, 12:29
