I suppose this is a newbie question....
If I use Toast 6 to encode to DVD a movie that's 23.whatever FPS, as opposed to 29.97, does that frame rate stay with the movie on the DVD, or does Toast add a 3:2 pulldown before writing it to the disk? I'm assuming that if the movie on the DVD is 23.xxx, that the player does the 3:2 pulldown in playback, and therefore a longer movie could be encoded in the same space, and therefore yield a higher picture quality. If a 3:2 pulldown is added during the encoding, then I guess it makes no difference.
Thanks.
If the software is worth a lick, and gives you the option to encode at 23.976fps than yes it would have to add the pulldown flags otherwise it would not be compliant and would not play on most dvd players.
Yes encoding at 23.976fps is much higher quality than at 29.97fps. Even though both are played back at the same framerate, the point is that you only have to physically store ~24 frames each second rather than ~30 which means more bits per pixel and more importantly the ability to encode using progressive frames rather than interlaced fields. With few exceptions, most of the typical software encoders people use are truly horrible when dealing with interlaced footage.
Force Higher FPS?
By therock003 in forum Software PlayingReplies: 5Last Post: 18th Apr 2012, 18:26 -
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
DVD ripping: does DVDFab give the best picture quality?
By Tom80112 in forum DVD RippingReplies: 25Last Post: 21st Feb 2010, 06:24 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 22:33
