Hello, I'm new to the group and have looked everywhere, but can't find a specific answer to this problem:
I have live concert 48khz wave audio transferred to my computer from DAT which I want to burn onto a DVD. I used CDwave to insert track ID's as I would for burning to a Cdr, I then burned to DVD (DAO), using Nero 6, burned as "data" because none of the audio burn options seem to support wave files, and I don't want to change/compress the audio at all. Now when I play the DVD I have 2-4 SEC dropouts, or "gaps" between songs. Do I need to author the DVD and insert chapters instead of using CDWave to avoid the gaps?
Which software would be best to burn this audio, and possibly add a slideshow of band pictures to see while the music is playing?
Any help/advice appreciated...
Thanks. RD
Results 1 to 1 of 1
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
How do I place track numbers/markers in a continuous wave file (Mix CD)
By V Bot in forum MediaReplies: 0Last Post: 28th Jan 2010, 14:07 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 22:07 -
Problem audio track
By didikai in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2008, 11:45
