  1. I heave succesfully converted my first DVD to MPG only 2 problems. First the movie plays fine but if you try to skip around it acts like its stuck on pause but the seconds still tick away... hmmm could be media player but I don't know.
    Second my .mpg is very large 928MB which obviously doesn't fit on a CD is there anyway to make it smaller without sacrificing too much quality or is it gonna have to be 2 discs? If I can make it smaller should I use the source file or the video I created?
    Thanx,
    Fat J
    Using:
    Smartripper
    dvd2avi
    TMPG(w/Sefy's Templates)
  2. smaller = re-encode
    split (what the cost of a CD anyway)= demux with TMPEnc-> mux with BBMpeg (beta 1 with max size at 730 MB -> burn with Nero
    May solve your other problem at the same time
    Ron
