Hi, does anybody know anything about Pinnacle Impresion DVD-Pro and whether or not it has previous/alternate versions? I have been searching for awhile now for programs that can make still menus as well as selectable subtitles. Looks like I've finally found it. Please give your opinions on this if you've used it!![]()
Results 1 to 11 of 11
Yes, it IS buggy. But I still use it occasionally.
It is still the cheapest software that you can buy that supports MULTI-ANGLE video. (If another one becomes available even CLOSE to it's price range, LET ME KNOW!)
Scott -
What do you guys mean by buggy? I hope I can still create a perfectly good DVD since it is my first try.
Examples:
Assets that you add in Project A will also be present in Project B when you create a "new" project.
Menus often don't remember timeout settings (e.g. "5 sec" vs. "Infinity")
"Return" doesn't always work the way you would expect it to.
Add an MPEG video to the timeline. Then Add an AC3 audio to the timeline. CRASH! This can be gotten around by saving after EVERY manipulation.
There are a few others, but those are the ones that bother me the most.
(and yes, I do have the most up-to-date version) -
Aw man...! I have AC3 audio.
Is there another tool that can do this?
Nope, no multi-angle video. I just need selectable subtitles and some trailer clips that can be activated by using still menus that I created in Photoshop.
DVD Lab says it can use Photoshop menus but doesn't say anything about subtitles. TMPGenc DVD Author, don't know about that one. And Encore is just plain expensive...
Help! It seems my program is called Pinnacle Expression and not Pinnacle Impression!
Does anyone know if Expression supports AC3 sound and selectable subs!? And trailers?!
It does subtitles? How come it doesn't say?
Do you know how long the trial lasts?
Subs and Impression DVD?
By Krzyhoo in forum Authoring (DVD)Replies: 3Last Post: 16th Mar 2011, 12:14 -
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 20:36 -
Mux: invalid video error .Impression DVD pro 2.2
By KYOPOWER in forum Authoring (DVD)Replies: 0Last Post: 24th Sep 2008, 14:58 -
Impression DVD Pro Problem "Mux: invalid video error&qu
By Kippo in forum Authoring (DVD)Replies: 1Last Post: 24th Sep 2008, 12:47 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 23:40
