My partner needs a laptop and is going to view one tomorrow.
It is a Compaq Evo N160C
512 ddr
1.8 ghz
dvd/cdrw combo
Tv out
2 x usb 1.1
14' screen
Modem
I have tried to search on the net for more information on this machine,but not having much luck,it seems the sights i do find are in a foreign language.
If anybody can help or give a rough price i should be paying this would be greatly appreciated.
dont know anything about the compaq evo's. i have a presario. sounds like its a little older computer. 1.8 ghz seems like its a little older, and the 2 1.1 usb ports are old as well. mine has a 2.4 ghz pentium 4 and 3-usb 2.0 ports.
I did a quick Google search, could find little about this machine. As sitlet said, seems like an older laptop. Spend more time looking for a good laptop. Laptops in general are difficult to upgrade. Your money is better spent with a newer machine.
I agree with red.....based on those specs sounds like an outdated machine by today's standards. Try to find something more updated and something that will last awhile, as laptops, unless you have the expertise are extremely difficult to upgrade yourself. Thats why they cost so much more than the desktops do. And when you do Goggle searches and find little on a particular model laptop, that should tell you right there that either they are no longer made and will be tough to obtain service for should something go wrong.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful.
Any Laptops with ESATA out there?
By jbitakis in forum ComputerReplies: 5Last Post: 10th Nov 2011, 13:20 -
What is the difference between these two HP laptops?
By jyeh74 in forum ComputerReplies: 5Last Post: 14th Mar 2010, 17:35 -
1080P help in laptops
By anirban in forum Newbie / General discussionsReplies: 14Last Post: 22nd Jul 2009, 05:56 -
Laptops
By didikai in forum ComputerReplies: 9Last Post: 14th Jul 2007, 22:46 -
Anybody here have experience with Toshiba laptops?
By Xylob the Destroyer in forum ComputerReplies: 8Last Post: 7th May 2007, 05:31
