Results 1 to 11 of 11
  1. i have encoded a film and done everything needed so its ready to burn but in scenes where the camera moves it will slightly stutter.it only seems to happen when i put audio onto the file without audio they work fine.i use tmpgenc to encode so anyone got any suggestions why its doing this and any tips to stop it!!!!
  2. Member SquirrelDip's Avatar
    Nov 2002
    What are your computer spec's? Just a guess, but it could be due to a machine with poor performance - if this is the case then it should play fine once burned (on a standalone player).
    Any other ideas?
  3. thats the thing its not just the pc it does it on it also does it once its been burned its baiscally like a dodgy cameraman to behonest as it seems to go slightly jerky when the camera moves in a scene.my computer has 512mb ram,80gb hard drive.surely that should be enough?????
  4. and also its 2.66ghz processor.
    Oct 2002
    is the camera movement quick? What were the setting used in Tmpeg? Did you you a CBR or VBR. Maybe the bitrate when the movment comes is not high enough. How long is you total movie?
  6. Member SquirrelDip's Avatar
    Nov 2002
    I agree that your computer should be more than adequate. Can you please update your profile to show your computer details.
    In adition to cdcox's questions, what is the format of your audio?
  7. its not my audio cos i just encoded without sound and it still stuttered it,it is any camera movement it slightleytops can i up the fps and is there any different encoders because tmpgenc is really getting on my nerves.
  8. Member SquirrelDip's Avatar
    Nov 2002
    Which one?
    Try Cinema Craft Encoder (CCE) or Main Concept -> most people here will argue for either CCE or TMPGEnc but I've found Main Concept to be really good (very fast and easy to use).
  9. Originally Posted by SquirrelDip
    Any other ideas?
    Thats a great dog!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
    To see, one only has to look.
    To hear, one only has to listen.
  10. I am going to go out on a limb here and suggest that your audio is not spec. If it is VCD, then it needs to be 44.1 kHz. If it is for DVD, then 48 kHz.
    Darryl
  11. the problem is it does it without the audio even being put onto it.i tried encoding without audio and it still did this jerky movement when it came to camera moving scenes.HELP!!!!!!
