I am hoping that someone may be able to help me here. I use a program called "Snagit" for capturing pictures from the internet and other places and many times need to email them or use them in forums as a post. Most of the time when I use these pictures there are limits as to the size in both inches and kilobits. My question is this, when I save the captured picture to let's say, My Documents file how can I tell the size of the picture (in inches and kb size) so I can know if I am within the guidelines for posting the picture. A good example of guidelines would be this very site, DDRHelp.com, this site requires all picture files to be 50kb or less. How do I check my picture for size, then how do I resize it to fit the site requirements? Your help is greatly appreciated. Thank you.![]()
Thank You,
GolfNut -
In explorer select view and detailed, the size will then be displayed. You can resize the image in any image editor, or apply more compression for jpeg example, I use paint shop pro for this.
Craig, thank you for the quick reply. I clicked on view in IE 6.0 but there is no "detailed" tab to click on or anything else under "view" that I could find that would tell me the size of the image, am I doing something wrong here. Thank you.
Thank You,
GolfNut -
Read Craigs reply properly
Thats windows explorer, not Internet explorer.Originally Posted by Craig Tucker
If you are not familiar with it, "my computer" view has the same options.
Capture picture stored on a DVD
By casualdvdmaker in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2010, 07:36 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
No Picture to capture?
By Brainfire in forum Capturing and VCRReplies: 4Last Post: 24th Aug 2008, 13:12 -
How do I capture a picture frame from a movie and make it into a picture?
By Hawkredtail in forum Capturing and VCRReplies: 7Last Post: 8th Sep 2007, 18:44 -
How do I capture a still picture from mpeg?
By illyad in forum Capturing and VCRReplies: 4Last Post: 15th Jun 2007, 20:30
