Hi there.
I want to burn two short movies (7 min each) on one svcd. (The movies are two different chapters ripped off a DVD). I know that this can be done using SVCD chapters, however I find it very complex to create them.
Is there another way of burning two movies on a single SVCD ?
I would really appreciate some help.
Thank you.
Just create a SVCD in nero and drag the two files into the window...brun...watch and enjoy
How about joining the two SVCD files with an editor and then burn the output (1 file) with Nero ?
Is there any difference with the method suggested above ? -
Doing it the way Boas999 said is the easiest, simplest and fastest way. Joining the two files together can cause synch problems but if you burn them as separate tracks you don't have to worry about that.
Need to burn TV episodes to DVD
By harishkumar09 in forum Authoring (DVD)Replies: 44Last Post: 3rd Mar 2013, 05:35 -
As many episodes as possible on one DVD5
By nharikrishna in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2011, 07:56 -
Multiple episodes in one vts
By c9806961 in forum DVD RippingReplies: 12Last Post: 15th Aug 2009, 02:35 -
DVD episodes to MPTS
By waveqam in forum Video ConversionReplies: 3Last Post: 15th Apr 2009, 16:37 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 15:09
