  1. I have 2 sets of VOB files. VTS_01_X and VTS_02_X. I used IFOEDIT to create new ifo files for VTS_01 and worked ok, but when I make ifo files for VTS_02, it overwrites VTS_01_0.IFO. How do I create an ifo for VTS_01 and an ifo for VTS_02? Is there a setting to create both ifo's at one time? Still need to have only one VIDEO_TS.IFO though
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    IFOEdit can't do what you wish it to do because you must have the create new video_ts and vts_01.IFO files option selected. The workaround is to move VTS_02 to another directory, rename it VTS_01 and create video_ts and VTS_01 IFOs for this. Delete the video_ts and rename VTS_01 to VTS_02 and move back to original dir.
    If in doubt, Google it.
  3. ...and then use DVDFab to create a new VIDEO_TS.IFO (which ifoedit can't do)
