Hi,
I always use TMPGenc to encode MPG2 files for DVD authoring, but I was wondering if the software I use for capturing footage makes a noticable difference to the quality of the final file, assuming that the encoding settings I use for TMPGenc, are the same.
I sometimes use Vegas to capture digital or VHS, but I have to render the avi before opening it in TMPGenc.
If I use Media studio 6 or 7, I can frameserve the timeline to TMPGenc, which I was told maybe a better quality option because I don't lose any quality by creatingan AVI first.
I also have Canopus's Lets edit which came with the capture card that I use.
I have virtual dub, but I've never really used it.
Would Virtual dub offer a better quality option if I was to capture and render before using TMPGenc ?
Or is there another program that I should take a look at.
Any thoughts appreciated
Cheers
Results 1 to 1 of 1
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
