I first decoded the DVD using DVDbackup, then ran "cat *.vob > my.vob" to concatenate all the vob's into one vob, then I dropped the my.vob file into DVD>DVD4 and selected audio track 1. My resultant DVD has the video lagging about 2 seconds behind the video, I did watch the whole movie and the sync problem is consistent throughout. I did recieve two error messages in my log:
M2VRequantiser by Makira.
Using 1.233329 as factor.
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/exrider/Desktop/my.vob.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/exrider/Desktop/my.vob.ac3 looks like an AC3 Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/exrider/Desktop/my.vob.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 29.970 frames/sec
INFO: [mplex] Bit rate : 6000000 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: AC3 Audio stream 00 (/Users/exrider/Desktop/my.vob.ac3)
INFO: [mplex] AC3 frame size = 1792
INFO: [mplex] AC3 AUDIO STREAM:
INFO: [mplex] Bit rate : 57344 bytes/sec (448 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 6556848
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio bd: buf= 16384 frame=000000 sector=00000000
INFO: [mplex] Scanned to end AU 14
++ WARN: [mplex] Sequence end marker found in video stream but single-segment splitting specified!
++ WARN: [mplex] Discarding incomplete final frame AC3 stream 0!
INFO: [mplex] STREAM bd completed @ frame 166685.
INFO: [mplex] STREAM e0 completed @ frame 127946.
INFO: [mplex] Multiplex completion at SCR=480076507.
INFO: [mplex] Video e0: buf= 17808 frame=127946 sector=01572610
INFO: [mplex] Audio bd: buf= 16384 frame=166685 sector=00148166
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 3173666854 bytes
INFO: [mplex] Sequence headers: 10681
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 127947
INFO: [mplex] No. Groups : 10681
INFO: [mplex] No. I Frames : 10681 avg. size103189 bytes
INFO: [mplex] No. P Frames : 32066 avg. size 39478 bytes
INFO: [mplex] No. B Frames : 85202 avg. size 9454 bytes
INFO: [mplex] Average bit-rate : 4759200 bits/sec
INFO: [mplex] Peak bit-rate : 7253200 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 177772
INFO: [mplex] AUDIO_STATISTICS: bd
INFO: [mplex] Audio stream length 298701317 bytes.
INFO: [mplex] Syncwords : 166687
INFO: [mplex] Frames : 166687 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 35 Buf max 5187
INFO: [mplex] MUX STATUS: no under-runs detected.
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing /Users/exrider/Desktop/my.vob.4.mpg...
exriderGuest
hey
reporting the same problem
But I vonvert from avi files to dvd, the audio sync is maybe 1 sec wrong, canīt fix this problem..fu*k!
Originally Posted by Guest
And I also got another problem with a AVI were when I convert it using TMPENGinc the video loses its audio for some reason in the conversion. thanx for any help
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
Audio Sync Problems
By nephesh in forum Video Streaming DownloadingReplies: 0Last Post: 12th May 2011, 08:10 -
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 14:50 -
audio sync problems after ripping dvd
By blubot in forum Video ConversionReplies: 4Last Post: 23rd Sep 2008, 10:14 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38
