First off great site which has helped me big time for a lot of things. What i was wondering is what's the difference between VR Mode and Video mode and when should i set my Pioneer 310-s to which mode? Is it a matter of opinion or does one have the advantage over the other in certain recording situations? Thanks for any help.
Results 1 to 15 of 15
In short, Video mode is compatible with most DVD players but is not editable. In contrast, VR mode is not very compatible but is editable.
When you feel that nobody loves you, nobody cares for you, everyone is ignoring you, and people are jealous of you, you should really ask yourself... Am I TOO sexy? -
Hi Philip, please explain.Originally Posted by PhilipL
I thought a dvd-rw would have to be in video mode to manipulate ( add chapters, edit, etc.) on my computer and reburn the polished product to dvd-r.God Bless -
Chasing playback on DVD-RW - is that the death of DVD-RAM as a video format??
I want to record to RW and be able to play back in other players, then record to the same disk again, with no finalizing. Am I correct in initializing and recording in VR mode
Is the -/+R disc that is created in VR mode or Video mode, or do you have the choice?No you can edit directly on the disc in VR mode in a PC. Alternatively you import the titles you would like, add chaptert to your hearts content, then create a DVD Video disc on +R or DVD-R.
I'm trying to figure out a way to create a scene selection from my old tapes (without starting and stopping the recroder), so I need to use VR mode and add (split) chapters. However, I didn't know what to do afterwards to make put it on an "R" disc in DVD-Video mode. The Ulead software does that?
Thanks,
brian -
PhilipL, first I'd like to thank you for your help. However, for some reason I can't get what you are suggesting to work. If I record using VR mode and add (split) chapters, I can't play or edit the disk using Ulead MovieFactory 3 (trial version- supposedly full version w/ 30 day usage) using my Sony DRU-510A or my Pioneer DVD-ROM.use Ulead MovieFactory3 to import the titles
I get the following error when I try to play or edit the disk:
No initialization.
Capture failed.
The created file is corrupt and unusable.
It will be automatically deleted.
[13011:5:3]
When trying to edit, I click on "Create Video Disk" then choose "DVD-VR" (I tried "DVD" also, and that didn't work either).
Thanks again for your help with this.
brian -
You're forgetting DVD-RW VR mode, the first format to use VR.Originally Posted by Gil T PleasureWant my help? Ask here! (not via PM!)
What about this ? Can this be a reason ?
This Trial Program has the following limitations:fewer menu templates, frames, buttons, and background videos. In addition, there is no Dolby Digital AC-3 support in the trial version.Pinnacle Studio 8 and DV home video editing (ver.9 already home)
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
8mm Video LP Mode to DV?
By dfeng in forum Video ConversionReplies: 2Last Post: 12th Apr 2010, 09:48 -
Video Fade In/Out Batch Mode
By quxote in forum EditingReplies: 11Last Post: 1st Mar 2009, 18:41 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27
