I've read posts here that seem to refer to VOB and MPEG files as interchangeable. What's the difference? Is there any? I'm just wondering because I've been working strictly with VOB files, and just need to use MPEG2VCR to do some editing, and what it outputs is an MPEG file. Do I need to do anything to file this before I can burn it to a DVD alongside VOB files? Thanks for your help.
A VOB file is basically the entire stream of data from the DVD. The one video stream (MPEG-1 or MPEG-2), up to 8 audio streams, and up to 32 subpicture streams are all multiplexed together to form a VOB file. If your MPEG2VCR program produces a MPG file you will need to use a DVD authoring program to get it back in the proper format for burning to the DVD. DVD-lab is a decent program that take your MPEG files and also your audio files and author a DVD with menus, chapters, and so on. I believe that it also has the ability to work with existing VOB files.
Tools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0
MPEG-4 ~ what's the difference?
By kr236rk in forum Video Streaming DownloadingReplies: 15Last Post: 3rd Feb 2016, 08:31 -
mp4 xvid vs H264 mpeg-4 avc quality difference
By johnharlin in forum Video ConversionReplies: 2Last Post: 8th Apr 2012, 07:38 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
after vob Demux the m2v and ac3 have duration difference
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2010, 01:45 -
Time difference between VOB and MPEG
By sambat in forum Newbie / General discussionsReplies: 6Last Post: 18th Aug 2008, 15:06
