After punching in the showview channels (sweden), I see that the channels suggested are not the "right channel".
When the recorder was installed, it scanned the tv-cable for signals.. and found about 13 channels.
I have entered "Home Menu".. and changed the "ShowView channels",.. but still there are channels which don't match the showview-code.
Some channels are on;
2,3,5,6 etc..
others are
cc8, cc7, cc15 etc..
How can I set these channels correctly ?
Are you talking about ShowView or VIDEO Plus+ (page99) ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
OK. I located Swedish manual and it is ShowView there and it should be on page 96.
and so on...Kanalinställning för ShowView (ShowView
CH Setting)
• Grundinställning: n/a (kan ej ställas in)
ShowView-systemet använder guidekanaler så att det
kanalnummer som anges för programmeringsnumren
för nummer som anges för programmeringsnumren för
ShowView skall överensstämma med rätt station.Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Nice!
but..
When I plugged in the device first time, it found & installed all my channels.
Then I went into the "Home Menu" -> "Initial setup".. and changed each channels number.
Like;
1 = SVT1
2 = SVT2
etc..
Now, when I push showview button, enter code, it doesn't seem to find the right channel.
I have entered the "showview channel settings", and found that
(not equal)
1 =/= SVT1
2 =/= SVT2
etc..
I have to set maybe
2 = TV3 and so on.. an that is confusing.
It seems that most of the channels are on "local cable channels, like 2,4,5,6 etc.."
But other channels are on cc7, cc8 and THESE CHANNELS - I cannot select in the "showview channels settings". ???
Tips on recording live Audio properly (help is very much needed.)
By rainrainrain in forum AudioReplies: 10Last Post: 28th Apr 2011, 13:02 -
CCE Luminance setting -- clarification needed
By eclipse95 in forum Video ConversionReplies: 14Last Post: 30th Sep 2009, 11:12 -
needed dvbt HD H264 channels player
By marcello.marengi in forum DVB / IPTVReplies: 4Last Post: 30th Aug 2009, 18:49 -
Hacking Pioneer DVR-5100H (DVR-510H)
By Destroyer in forum DVD & Blu-ray RecordersReplies: 145Last Post: 5th Mar 2009, 14:46 -
AMV nooby~tips needed!
By KittyLuck in forum EditingReplies: 12Last Post: 23rd Jan 2009, 11:24
