I was wondering if there is any firmware I could use to increase the ripping speed of my NEC ND-1300A? The drive is a year old and originally came with 1.05. I then recently upgrade it to 1.08(non hacked) version. Im only interested in upgrading if the firmware is safe and has no side effects since its my only DVD drive and I don't want to screw it up..
Results 1 to 9 of 9
Download the Bin Patcher from here:
http://www.herrie.org/modules.php?name=Downloads&d_op=viewdownload&cid=39#cat
Only select the rip limit option and that is all that will be changed. -
I downloaded it but how do I get it to work? I selected "2x rip limt" and hit "Auto" and then it asks what bin file to patch. Not sure what to do??
The details on the latest Hacked firmware say that it only works on drives with original firmware 1.06 -1.08. Mine was 1.05. Anyway it looks sketchy and from reading the comments, some folks are having some issues with it. I just want to remove the rip limit. Can anyone provide any help to install the Bin Pathcer listed earlier?
OK, problem solved. I downloaded the older Hacked firmware 1.07v4 which doesn't have all the book type features. It now starts ripping at 4x and finishes at 12x for a single layer disc. Much faster
Hi,
I got NEC 1300a with 1.09 official firmware. Then I flashed it to 1.08 hacked. The rip speed did not change. For DVD Decrypter, it started at 2x and ended at 5x. I also tried 1.07v4 hacked. Same thing. Is this normal? Thanks!
cchang -
I also use DVD Decrypter. It looks like yours is not locked becuase you can get 5x. Try different DVD's.
Hi,
I finally flash the 1300a to 1.0A. The rip speed is much faster. It started at 4x and ended at 9x.
cchang
C 1300 disc is dirty error on NEW blank dvd's
By rrtbusa in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd May 2010, 09:25 -
Hauppauge HVR-1300 and Virtualdub Cannot Capture
By JonnyAlpha in forum Capturing and VCRReplies: 5Last Post: 13th Feb 2010, 10:39 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 23:21 -
Do newer drives rip dual layer discs any faster?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Feb 2008, 10:40 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 21:28
