I have a feature only dvdr and I want to ripp just the feature not the audio into m2v file so I can use dvdlab and place a seperate ac3 file over it.
How can I ripp a m2v file off a dvdr? and what software will I need?
All help would be appreciated.
Thanks.
DVD Shrink, reauthor, select the part you want and rip to a vob. Import the vob in dvd lab and choose to demultiplex and you will get a m2v that you can add new audio to.
Doesn't VOBEdit do this?Originally Posted by Castor troy
Yes it does, and also rejig, dvd decrypter, smart ripper. If you want to select a specific part from the dvd is dvd shrink kinda easy to use.
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 09:13 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 05:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
