  1. Hi, I got a problem, tried to search the page but didn't find what I was looking for... so I'll try here.
    I have a hole DVD (VIDEO_TS.IFO, VTS_01_1.VOB etc etc, that kind of stuff) and I is ready to be burned on a DVD-R.. the thing is this.. How do I add a menu to it? So I can choose to play all track at once of or choose track 1 to 8 and just play one track and then go back to the menu.. Can't find any program/guide on how to do it :/
    tmpgenc dvd author, add dvd video
    dvd-lab
    but you will lose subs and multiple audio tracks if any.
    Jan 2003
    If you are wanting a already made menu off a movie then I would use DVDshrink. If you are wanting to make your own menu then take that to DVDlab. There are plenty of guides for both programs. If you can clarify what type of menu you are looking to do then we might be able to help you out more.
  4. It depends on what you want, cause it can be done with a whole bunch of programs... DVDLab, Studio, etc
  5. Well, I don't want to remove anything (no sub chap etc).. or editing the movie, just want to add a menu to it..
  6. I have the same question. TMPGEnc DVD Author is an excellent program and I use it the most, but unfortunatly it is not able to deal with subtitles.
    Is there a program with the ease of TMPGEnc DVD Author but does let you keep the subs when you put 2 DVD's on 1 DVD-R?
    I used DVD-Shrink already, I got a DVD including the subs, but no menus, so the second movie was only available using the title funtion.
    So, I would need a program that can add a menu to an already authored DVD, without changing anything on the DVD. Tried DVD-Lab but I lost the subtitles again.
