When I try to convert a Xvid videofile to MPEG1 (or 2) I first rip the sound off and store it as WAV...
Second I try TMPGEnc where I use the videofile and the WAV file....
When it is all done the sound of the video is all out of sync.
Could someone make or point to a noobguide how to do this correct?
I have tried for several weeks now....
What I miss is a guide on how to convert the videofile to MPEG (I know there is one but it is difficult).
When I am done with converting I use a program called DVD Architect wich I am happy with.. but it won't use other files than MPEG....
In advance... thanks.
first of all does the sound play in sync when played as an xvid?
i think when you strip the sound from the Xvid to wav its best to use virtualdub i am told because this can tell you if there is a delay in the sound (so i am told....never used it myself)
what i do is load Xvid into TMPG.........
when you get to the screen that lets you choose 'other settings' click on this and click on 'source range'.
now choose a part where people are speaking and press the 'mark in' button.......the move the FFW arrow >> so its 1 min ahead and press the 'mark out' button.
now you have set a range for testing the sync.
on that same screen is an audio correct setting.........try -400 and encode it at that setting.
play back clip to see if sound is in sync.
if not add or subtract from -400 to get it right.
it takes less than a min for each try.
when you have the correct delay set make sure you select the full frames/range again and encode.
hope this helps m8
KYUSS -
Thanks for the reply...
Yes first I did use Virtualdub to rip the sound into a WAV... second I use
TMPGEnc to convert....
and then to make a DVD with menu I use DVD Architect to create it.
Takes forever and ever but it workes great and I can play the DVD's with a PS2 if I want to.
I just managed to try alittle of what you did say as I had to go to work
but yeah it seems like I just have to try myself down to see what workes out best.
The sound on the Xvid file when I play that one (the video that is) well it workes out fine, no delay in the sound.
When I first tried to convert it the sound looked alright, but then fell out of sync for some reason.
Looked like I could hear things happen before I saw them.
So the sound was alittle ahead of things.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
