I had to reinstall my OS on my Mac running Panther. I then had to reinstall my dixv codec and ffmpeg. The installer didnt work, so I did it through the terminal. Everything seemed to be installed. However, when I try to make a dvx3 using Mencoder, progress just dings and doesn't work. Converting to divx via ffmpeg seems to work, but from my experience, the sound is usually a little off if I dont use mencoder.It used to work, now I'm stuck. Any Idea how i can troubleshoot?
Thanks.
Mitch
Results 1 to 1 of 1
AnonymousGuest
DVD recorder wont recognise disks
By ruthybear in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2010, 13:16 -
wont recognise camera connected
By sarah1 in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2010, 06:09 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
Anyone recognise this noise?
By DaveQB in forum Capturing and VCRReplies: 26Last Post: 20th Oct 2009, 10:49 -
MY PC WONT RECOGNISE PANASONIC NV - GS5 !! ANYONE HELP PLEASE ??
By GRENDLE in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 25th Feb 2008, 16:34
