Hi everyone. I hope someone can help me. I have several vcds of movies I brought with me from europe which tells me they are in pal format.
each movie is split into 3 cds and i would like to put every movie altogether in one dvd+r disk.
I tried everything I can think of.
my first try was following smurflord.com guide. used isobuster> and tmpgenc auth and wrote it with the built in writer with menus but the disk wouldnt play in my dvd.( BTW I can play the vcds in my jvc standalone player)
the last thing i tried was encoding the mpg files with tmpgenc to ntsc created video_vts files and used dvdshrink to a small size but no luck. the files are huge and i cant burn them.
can anybody help me please?
I have xp OS and i have nero,mydvd,isobuster,tmpgenc,tmpgenc auth
Don't know if this will work on vcd's, but I VERY successfully converted PAL dvd to NTSC mpeg2 using Canopus ProCoder, which creates a .m2v & a .wav file. From there you can author your dvd using whatever method suits you. By the way......convertin this way loses menues, but they can be recreated.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 18:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 03:22 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
please help
