Hi
Ive been having trouble with playback on dvds recently on my toshiba Dvd player on few films it will pause the films on itselfWould using a Dvd cleaner help my player ? as the dvds are clean ....
.o0 Vision74 0o.
No, using the DVD cleaner does'nt have much of an effect. I have the same problem and when i used the DVD cleaner it had absoulutely no effect.
But you can try slow speed burning, it might help. -
The best bet here is the media you are using ........
If this has always happened, then its the media, if its just started what have you changed (media, burn speed, etc, etc)
I had this problem when burning 2 movies per DVD, or when teh movie was at the evry end. It would start stuttering, pausing or sometimes just freeze
I finally managed to get some Princo G04's from my local independant computer supplier and all problems disappeared. I've burnt DVD's so close to the edge you can barely see it ... Still no problems
Try changing your media, if you can get them pay extra for Princo G04's Purple Dye. Fantastic, no problems, very compatable and will easily burn at x4. Worth the expense
Also, these are supposed to be very compatable especially with X-Box and PS2 backups, but I can't test that yet
I used to use Mirror Platinum, not any more
DVDs skipping and freezing after burning
By rogue_edit in forum Authoring (DVD)Replies: 4Last Post: 25th Mar 2010, 14:49 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Standard Backup DVDs freezing on my new Sony BlueRay BDP-S550
By bribri25 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 5th Jan 2009, 14:46 -
brand new oppo-980H freezing on some aftermarket DVDs
By mikhail_f in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Dec 2007, 18:34 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
