  1. Lover of all things retro
    Arizona
    This is the message I'm getting in TMPGEnc...the latest version...can't find 12a except for the spain one. I "simple de-multiplexed" my Flask/Pana MPEG file then when I "simple multiplex" I get this error at the end.
    6 s packets cause buffer underflo
    The MPEG file might cause error when it played.
    HELP!
  2. You can try and choose another stream type, usually this works. Don't leave it on auto, choose the correct one.
  3. I also get this if the audio is the wrong bitrate (or the video for that matter), double check you streams.
  4. vice86,
    Don't worry about it... This on the rare occasion happens to me too and I'm at a loss to explain why. Perhaps there's a problem at the very end of the mux??
    In any case, 6 packets is not going to cause any problems. If there is a video/audio bitrate error (e.g., trying to mux video and audio streams with incorrect bitrate with the MPEG-1 Video-CD setting) the number of packets that are off will be MUCH higher (and then you may have A/V sync problems).
    If it really bothers you, you could demux and remux your Panasonic MPEGs with bbMPEG.
    Regards.
    Michael Tam
    w: Morsels of Evidence
