  1. I have two sets of .vob files that I created (basiclly .mpg files renamed) that I need to create ifo files for. what program best does this?
  2. Member wulf109's Avatar
    Jul 2002
    IFOEDIT can create ifo files from vob files. However simply remaneing mpg to vob will not work. IFOEDIT will make ifo files from renamed files but they will not play. A better way would be to demux the mpg into it's elementary video/audio streams then use IFOEDIT's DVD author function to create all the required files,ifo and vob,these will play.
  3. OK, I am getting there. I have VTS_01_x.VOB and VTS_02_x.VOB, I used ifoedit to create ifo's for the first set of vob's. How do I create an ifo for the second set of vob's? ifoedit wants to keep using VTS_01
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    You have to name your VOB files for the first set as:
    VTS_01_1.VOB
    VTS_01_2.VOB
    VTS_01_3.VOB
    VTS_01_4.VOB
    and so on
    Your second title set needs to be named
    VTS_02_1.VOB
    VTS_02_2.VOB
    VTS_02_3.VOB
    VTS_02_4.VOB
    and so on
  5. That is how my naming sequence is. But when I pick VTS_02_1.VOB as the first vob in the set, it still writes out a ifo for VTS_01, overwriting the ifo it already made for vob set VTS_01_1.VOB
