Im looking to author a DVD that has multiple audio eg directors commentary, foreign language. At the moment im using TMPEGnc DVD but i dont think i can do it with this. I know DVD Lab allows this but my trial has expired and i dont want to pay for the full version (unless theres no other option).
Are there any other (hopefully free) authoring tools that allow you to create multiple audio tracks or a way to do it with TMPGEnc DVD?
Any help greatly appreciated.
It isn't possible with tmpgenc dvd author.
Ifoedit is free but you wont get any menus.
dvdauthorgui is also free but the menu creation is kinda limited. -
You can try ReelDVD, it has a free trial and has a good set of features (including at least 3 audio streams if I remember correctly).
You can do it with DVD Lab. You need to use IFOEdit first to author the title as a single movie multi audio track DVD. You then use DVDDecrypter or SmartRipper to "rip" the VIDEO_TS folder into a single large VOB file and you feed this to DVD Lab as an asset. You don't demux it within DVDLab. You can use DVDLab to create menus, chapters, etc.
One of the things you can't do within DVDLab is to select the audio track through a menu. You need to use the DVD Player's audio track selection button for this.
The alternative tools are pretty expensive to buy. I guess ReelDVD and Adobe Encore are probably the "cheapest".The more I learn, the more I come to realize how little it is I know. -
Actually, under the Guides section to the left, look for DVD-lab. There is a guide on how to make an audio menu. It involves the use of DVD-lab and IFOedit. I haven't tried it yet, but it looks pretty straightforward.Originally Posted by SaSi
The latest version of ReelDVD supports 8 audio streams and 32 subpicture/subtitle streams, but it does not have a provision to create audio or subtitle menus.Originally Posted by DVOTools used: ScenalyzerLive 4.0, Adobe Premiere Pro 2.0, Adobe After Effects 7.0 Professional, Adobe Encore DVD 2.0, IFOedit 0.96, DVD-lab PRO 1.53, Adobe Audition 2.0 -
Have you tried DVDAuthorGUI? It's free and now allows for multiple audio/menus/subs.
DVD to h.264 -- with multiple audio and subtitle tracks
By Ozo in forum DVD RippingReplies: 12Last Post: 16th Nov 2012, 07:34 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
m2v and ac3 multiple audio tracks to DVD
By gameroftheuk in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 16:55 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
VOB to .ts with multiple audio tracks
By csaba1985 in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2007, 08:28
