Hey there, ... how are you?
I have unlocked my AIWA XD-DV370 DVD player with a remote combination ..! It does work fine, but all DVDs with the region code are only in black/white ...
Did anyone experience this ... any ideas??
Cheers,
T-MOW
Hi
I have the same dvd player and used the remote control to unlock the code.
All region 1 disks were working in colour no problem until I moved it to a tv upstairs (older one) I think that the problem is that my older tv is not NTSC compatible.
The minute i put it into my newer tv the dvd's were back in colour.
Suggest you check the TV . -
Thanks for the info ... freddyfocus!
I'll check with a newer TV then ... it's cool to know that you experienced the situation as well ... so I'm not the only one ... phew!
Cheers,
Teemo -
Yo fellows...
The problem is the the TV indeed. NTSC signal on PAL tv causes b/w playback. This can however be solved real easy. Because your player had a PAL region before, you never had this problem... but the dvd output signal is probably set to "AUTO" in the DVD-player's settings. If you set it to PAL, all outgoing signals will be converted to PAL
Hope this helps....
Greetz,
pSyChO dAd
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
real newbie here.. help with my set up >Panasonic AG170 & Aiwa multisystem
By TurboJoe in forum Newbie / General discussionsReplies: 5Last Post: 29th Jan 2011, 11:20
