I use dvd lab solely, but I have recently run into limitations from the software that I would like to incorporate into my dvd's. The thing I want to accomplish is:
In hollywood dvd's you will see a motion background on the main menu and after it has finished (and before looping) the text/object links appear (sometimes fade in, etc). And then on the loop, those links remain as well as the position of whatever nav object you were on.
Is this possible with the software I am using (be aware I am willing to try ifoedit)? If so, can you steer me toward some sort of tutorial somewhere or a nice push in the right direction?
There are many things I would eventually like to do but I figured I would start with what I think is a good place to get my feet wet.
Thanks in advance for your help!
