I am trying to copy an already burned DVD-R onto another DVD-R.
Some of my DVDs copy fine, with no errors. While others get to a certain point in the disk (sometimes in the middle, other times at the very END of the disc) and Nero comes back and says "error reading disc" and the burn ends.
The DVDs with errors play fine all the way through on my DVD player. Maybe a hiccup on that spot, but that's the extent of the error.
How do I go about saying "ignore errors" or what have you on my DVDs so they can copy onto another disc? Different copying program besides Nero?
These errored DVDs have been converted on DVDShrink and burned onto either Memorex or Ritek -R media (both types have had read errors). I then go to copy the DVD in Nero, or DVDShrink and both come back with errors in the same place on the disc, but plays fine.
How do I get around these errors on the DVDs?
Well, you start by using a better quality disc to record on in the first place.Originally Posted by jprock
Do a search for "MEDIA FADEING AFTER 6 MONTHS" and you will probably panic.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
These discs were just written no more than 2 weeks ago.
I have read through many forums and most agree that Riteks were the media of choice.
So what you are trying to say is that the media slowly deteriorates after time?
What media do you suggest, SLK001? -
DVD Decrypter has an "Ignore read errors" check box that you can select in the settings.
what media to use depends on your writer. But thats easy to figure out, left column, dvd media
Vegas movie studio 10 "out of memory errors"
By magillagorilla in forum EditingReplies: 19Last Post: 25th Oct 2011, 11:58 -
HowTo deal w/ nasty "audio streams have diff sample sizes" errors in WAVs!!
By KneeRow in forum User guidesReplies: 0Last Post: 25th Jul 2011, 13:43 -
I don't understand these errors saying "wrong version".
By saltyjd1 in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Mar 2011, 15:52 -
Out of Memory Errors Re-Coding "WAR" for Backup
By Newminds in forum DVD RippingReplies: 1Last Post: 6th Jan 2008, 13:00 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 18:32
