I just purchased a Dell8300 3Ghz, 512Mb RAM, 120Gb SATA drive, DVD-ROM drive,Nivida GeForce 5200FX graphics, internal audio and NIC. I added 1 Gb of RAM and a Plextor 708 dual burner.I would like to add a second hard drive to capture video to. The DVD-ROM and the DVD burner share the seconday IDE cable. I have the primary IDE cable free. Should I get a second SATA drive or will the two SATA drives share resources similar to two IDE drives on the same cable? Will any cards in the PCI slots affect the performance of the SATA drives? Or should I get an IDE drive, and if so, should I make it a boot drive or a capture drive?
I have a bunch old VHS tape that I want to convert to DVD. I am going to use a Canopus ADVC-100 or a Sony Digi-cam. I don't own either one yet so I am leaning towards the Sony. The Sony puchase would also update my old VHS camcorder. So now this leads to my next question. I am looking for software to do the conversion. Is there any one software that will go from capture to DVD burn or should I try the free stuff that came with my Plextor burner and Firewire card first. Thanks JIm
Results 1 to 1 of 1
SATA to IDE adapter.
By Poppa_Meth in forum ComputerReplies: 31Last Post: 6th Jan 2014, 16:47 -
IDE and SATA
By HotDamn! in forum DVD & Blu-ray RecordersReplies: 11Last Post: 6th Mar 2010, 01:49 -
sata vd ide
By dymx in forum ComputerReplies: 3Last Post: 9th Sep 2009, 09:04 -
Sata v.s IDE
By tapal in forum ComputerReplies: 4Last Post: 22nd May 2008, 06:04 -
IDE + Sata Drive ?
By StoneColdWhat in forum ComputerReplies: 4Last Post: 17th May 2007, 16:50
