I am wanting to do real-time mpeg2 captures of VHS tapes to my computer. I already have a JVC HM-DH30000U DVHS player with TBC, 3DNR and realtime MPEG2 encoding capabilities. The only problem is, you have to have a DVHS tape loaded i the machine for it to do the realtime encodes, so obviously I can't play the tape and have a DVHS tape in at the same time.
Should I, buy another VCR to pass the signal through to the DVHS and then iLink to the pc to capture the encoded MPEG transport stream?
If another vcr, would a simple 4-head vcr with s-video out be sufficient considering that my current DVHS vcr has TBC and DNR already on it? Or would I be losing something in the process?
Should I just buy a capture card with mpeg2 encoding capabilities built in to it? If so, for the money, would you reccommend a hauppage WinTV PVR-250, or an ATI All In Wonder Radeon 9000 Pro (doing this I would need to switch video cards when playing certain games because it's not as powerful as the nvidia I have in there now).
Or should I continue to use my current capture card (crappy BT chipset) and buy mainconcept encoder for realtime captures.
Lordsmurf, what are your thoughts on this (I can almost hear your answer now, GET THE ATI!!)
I'm an old ATI user and loved the card.
I now have a ADVC-100 and just this week tried the MPEG2 MC1.4 and the results so far are superb.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I have the ATI AIW 9000 Pro. So far I haven't found anything about it that pisses me off. Not a bad card at all.
Either get the 2nd VCR (but make it a good one, in the JVC S-VHS line) ... or go for an ATI AIW card and swap primary display in the BIOS as needed.
ATI AIW option is probably easier AND cheaper in this case.
I like the Hauppauge too, but not over ATI. The BT chip card is not even an option - too many quirks on them, not worth the trouble.Want my help? Ask here! (not via PM!)
if only I had 2 agp ports.. I can't find a PCI version of the AIW card in my area.. I guess i could always buy online..Originally Posted by lordsmurf
Thank you to everybody who has posted replies. I have downloaded a trial version of mainconcept and I am absolutely floored by the results. I can capture MPEG2 in realtime with 1 pass VBR and i'm only using 40% processor time. Obviously I haven't had a good chance to test it out as i've only had it for about an hour, but from what I have seen it is giving me quality that is on par with capturing HuffyUV and encoding with TMPGEnc. At first I thought it was a bit lacking in the options department, until I saw all of the things hidden on the rightside of the screen in advanced options. Now to just import my favorite Quantization matrix and I'll be all set.
I should probably still eventually get an ATI as my capture card always captures some blank pixels on the left side of the capture, but since I am only watching these on a SDTV then the overscan should take care of that anyways.
Convert ATI AIW .vcr format to anything?
By madmartian in forum Video ConversionReplies: 14Last Post: 4th Jan 2012, 07:59 -
Which VCR should I buy?
By rudolf016 in forum Capturing and VCRReplies: 2Last Post: 24th Nov 2011, 22:05 -
I would like to buy one of these two VCR panasonic ...can someone suggest
By Giasan in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 11:41 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25 -
Where can I buy a VCR?
By Xenogear900 in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 01:28
