We're creating a .AVI video that will be sent to various employees out in the field to view on their PC's.
Because we dont' know the exact configuration of each of their media players, is there a way to create the file or the CD so that the proper codec's are included.
We just tested it on a PC here and the version of Media Player we had didn't have the proper codec and wanted to connect to Microsoft for an updated one and it's blocked by our firewall.
Ideas on how to make this video so all can watch it without any problems?
Hi Touchdown,
Check out VCDEasy (freeware if you get the earlier version) and TMPGEnc (freeware if you're only doing encoding to MPEG1 - VCD's).
VCDEasy is an easy to use front end for producing VideoCD's. It uses TMPGEnc (or one other, but TMPGEnc is considered to be one of the best) to take your AVI and convert it to MPEG (1 = VCD, 2 = SVCD / DVD).
Check out the links in blue at the top left of the page for definitions of VCD (low quality, but can be OK if good AVI), SVCD (better) & DVD (best).
MPEG is a very common format, and so should be OK with pretty much everybody. I don't think you're ever gonna get it to be OK with everyone, just "very nearly everyone".
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Are you looking for some kind of AutoRun Menu?
http://www.divx-digest.com/software/index4.html#launchers
MKV Audio + AVI Video to avi using ffmpeg?
By kwanbis in forum Video ConversionReplies: 9Last Post: 15th Apr 2012, 21:45 -
hi8 to avi Vs digital to avi capture using S-video connection?
By jaybird in forum Capturing and VCRReplies: 3Last Post: 29th Apr 2009, 23:48 -
[MOV => AVI] Need help, why the result AVI video cannot be played?
By ohboy888 in forum Video ConversionReplies: 16Last Post: 2nd Mar 2009, 14:51 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 20:16 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23
