i am trying to encode and VCD MPEG file (4:3 NTSC 29.9 fps)to a DVD MPEG2 16:9 file on TMPGenc.
Every time i do this the audio & video on the new file are out of sync but not so on the source.
What can i do?
Just to save you some time in browsing, you'll notice that the incoming stream is 41000hz, and your outgoing stream is 48000hz..This means that your sound is being sped up, thus synch problems...
Look at demuxing the source audio and video, resampling the audio separately in an audio editor to 48000hz, and use this new resample as your audio source for the new DVD encode...
Good luck!!!
How To Cut MKV Without Audio/Video Sync Problems
By Eva-Unit01 in forum Video ConversionReplies: 12Last Post: 2nd Mar 2011, 08:11 -
Video Audio Sync Problems
By Johnnysh in forum DVD RippingReplies: 11Last Post: 26th Jan 2011, 01:47 -
Sync problems after merging mkv video with mp3 audio
By billman1234 in forum Video ConversionReplies: 5Last Post: 29th Jun 2010, 15:00 -
Audio sync problems when re-coding captured video. Any Solutions?
By uart in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 17:34 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 08:20
