i got my ink refilled to day total cost $35
came home and printed 4 dvds no problem, ink seems to be legit and dried just as fast as the original. i really can't tell the difference
Results 1 to 9 of 9
Nice!
What kind of ink did you use? And what tools? Was it easy?
I read you should minimize the time you do not have any cartridges in the printer, so i guess it was a quick task to do? -
My suggestion is to have 2 sets of carts. If the cart is out of the printer too long, then the heads can dry on 2 sides. So I suggest you fill the empty spare just before replacing the low cart that is in the printer. Then store the one you just removed in a ziplock bag, or other airtight container (the smaller the better, remove as much air as possible before sealing the container). The simply repeat when the time comes. Maybe a little more expensive, but it could save you time and ink when trying to clear a clog.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Yes!!! Tell us where you got the replament ink. th chip resetter and how you did it. That would really help. I too use the R300 and just spent like $80 for ink replacements! ARHG!!!!!
No DVD can withstand the power of DVDShrink along with AnyDVD! -
I hope you didn't throw the empties away.
We want more info!
The UPS man just dropped off my R300 at home, might have to leave work early!
NWF_Snake -
Hello
Please post more information. Refill instructions you used links you used.
MrBossman -
I am looking for a complete kit with ink refills, resetter (for original cartridges) and a set of extra cartridges wich also can be resetted.
I will use my Dremel type multitool to drill hole for refilling if that is needed.
Anyone who know where to buy good and low price 'refill-kit' ?
i think you guys mis understood my post. i did not do it myself i had it proffesionally done. i live in toronto and this is the company that i used
http://www.saveoncartridgeplus.com/html/toner_refills.html this was the first one like this they did the guy was constantly on the phone with someone then a fax came with the schematic of the cattridge. he took about 1hr to do all six but it was well worth the wait.
apparently they are a franchise so maybe there is a location close to some of you.
futher update i did 7 more dvds last night no prob same drying time as original ink no smearing yet
Do Lexmark printers reject refilled ink cartridges?
By yoda313 in forum ComputerReplies: 14Last Post: 21st Oct 2012, 15:02 -
epson px720wd
By davechubb in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2012, 12:42 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19 -
Epson R280
By ultraman36 in forum MediaReplies: 2Last Post: 11th Nov 2007, 12:26 -
Resetting HP Printer Ink Level for Refilled Cartridges
By galactica in forum ComputerReplies: 11Last Post: 5th Jun 2007, 05:21
