im using tmpgenc to encode a movie but at about 64 % it comes up with stream line error and stops can anyone explain what this means and how to stop it.
Results 1 to 9 of 9
Hi clactongirl2002,
You need to provide more details, like:
1. What is the format of the original file (i.e. AVI)?
2. If it is AVI, use GSpot or AVICodec to get details of the file and post those.
3. If it's not AVI, try to provide any other info (is it MPEG1 or 2 etc.).
4. Are you using TMPGEnc's wizard or your own settings? If the latter, what settings?
5. What's the full error message?
6. How's the seaside in sunny(?) Essex?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
they are both avi files and im not using wizard im using my own settungs.the settings im using are system video and audio,25 fps,2 pass,interlace, what else do you need to know cos this is really confusing.
Hi clactongirl2002,
Originally Posted by clactongirl2002Originally Posted by daamon
Oh, and you forgot:
Originally Posted by daamonThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
right i downloaded gspot and it said
ath bad boys 2,size701 mb,stream type opendmlavi,imrr 1.00,I/L1 vid frame(42ms)p=504 split:no,video codec,4ccdx50/divx.name divx,runtime 02.26.46,x:y512x208,bitrate 533 kb/s,23fps,Qf0.209 bits/pixel,audio name 0x0055 mp3 ID'd as mpeg1 layer 3,bitrate 126 kb/s(63/ch stereo)VB lame 3.90,Fs4800ohz,comments and metadata,ISFT software virtuadubmod 1.5.1,junk (ASCII virtuadubmod build,junk ASCII release.is that enough info,and by the way its dreary and horrible here.
Hi clactongirl2002,
Near enough exactly the same as someone else. See:
https://www.videohelp.com/forum/viewtopic.php?t=203908&highlight=
...except their AVI is an Xvid, whereas yours is a Divx. But you've both got MP3 audio - probably the cause of the problem.
There's info in the link above that should (hopefully) do the trick...
P.S. Weather's the same in Euston too...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
thanks a lot for your help but im a real newbie, ive tried using wav before with this and diddnt get any sound and i installed scmpx cos i coudnt work out how to open toolame,could you please help me step by step to extracting audio into a wav file and then tell me the setting i need in tmpgenc please.
Hi clactongirl2002,
If you click on (the highlighted) VirtualDub, it'll take you to the page on the site with the info, comments etc. about it. It also has a list of guides that use VirtualDub. Scan down and you'll see "How to convert the audio in a video to WAV (or MP3)". That'll take you to the link below:
https://www.videohelp.com/guides.php?guideid=101
This link gives a brief summary of the guide, and the link to it. It may not be exactly what you need, but should point you very much in the right direction.
Please remember to rate the guide as this has recently been introduced by Baldrick and it'd be useful if people used it. It'll be useful for people in future too...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
MPlayer stream error
By nic3 in forum Software PlayingReplies: 0Last Post: 31st Jul 2011, 17:23 -
No output: /bin/sh: -c: line 0: syntax error near unexpected token `('
By marmi in forum ffmpegX general discussionReplies: 4Last Post: 16th Jan 2011, 09:14 -
feature request: Vob2mpg pro command line option for audio stream selection
By Ahimoth in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Sep 2009, 05:42 -
Error while decoding stream #0.0
By brassplyer in forum Video ConversionReplies: 0Last Post: 26th Aug 2009, 05:04 -
Walk The Line Ripping Error?
By LCE in forum DVD RippingReplies: 4Last Post: 12th Nov 2007, 13:36
