I flashed my ND-1300A with 1.08V2 to try bitsetting. Now I want to flash it to 1.09 firmware but the flash program says it can't find the drive. The drive is operating normally but I notice that Conrtol Panel and Nero both say "_ERROR NEC ND-1300A". Anyone know what happened? Can it be fixed?
RESTRICTIONS:
- This firmware runs only on a original NEC 1300A v1.06 to 1.08 !!
The firmware does serveral checks and if it will find
incompatible hardware the drive would return the ident string
_NEC_ERROR! ND-1300A as an error message
to windows (only) applications instead of the correct string:
_NEC_DVD_RW ND-1300A
In this case go back to a (original) compatible firmware.
http://forum.rpc1.org/viewtopic.php?t=21114
Samsung BD-P1590/BD-P1600 Foreign Firmware Flash/Region Free Issue
By 5arge in forum DVD & Blu-ray PlayersReplies: 12Last Post: 15th Apr 2012, 20:32 -
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 12:24 -
flash player won't work in win 7
By Shotobits in forum Newbie / General discussionsReplies: 3Last Post: 27th Mar 2010, 06:28 -
Is it possible to flash firmware onto a non-original DVD burner???
By suomalainen in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2009, 17:17 -
PC won't boot. Only freezing at Gateway flash screen.
By rijir2001 in forum ComputerReplies: 8Last Post: 19th Jun 2007, 11:20
