I dont have a superdrive yet, but I tried your method of saving a disk image. I tried a 500 mb file and it said "There is not enough space on this volume to complete this operation" It did go to toast but it had 0 bytes. Also I have a 80 gig harddrive.
I also don't understand what you mean by "In dvd extractor go to file>save image point it to the dvd in your drive. Then it will ask you where to save the image, point it to your harddrive, save image."
I dont exactly understand the term point either. I tried all different ways of doing this and nothing worked.
Any suggestions?
Results 1 to 9 of 9
As others have mentioned, most newer DVDs come as dual-layered now, so a simple copy won't work.
Regards.
Michael Tam
w: Morsels of Evidence -
Anyone got links for Toast and DVDExtractor thingy Got stuff for PC but not Mac
Cheers
Me
Although the process outlined above is on a Mac for a direct disc copy, is it possible to extract the parts of the vobs you want using a program like SmartRipper or similar, and then author a new DVD? I know when I rip for VCD, I dont let SmartRipper get the DTS soundtrack, alternate language tracks, subtitles, PCM soundtrack, etc ... which makes the vob copied to my HD a somewhat smaller file. Doing this may get some films under the 4.7gb barrier.
A ripped DVD takes about 3 to 4 GB without multilangual, subtitles, menu's, extra's , etc.
Only a very long movie wouldn't fit on a 4.7 GB DVD
Mark -
Very true...
However, a DVD without the extra soundtracks and subtitles and all the other nice bits is like...a curry without enough spice. All the important bits are there but it just isn't as tasty.
Regards.
Michael Tam
If you're copying DVDs to get all the neat extras, just buy the freaking DVD. I mainly copy DVDs because my obsession with movies is much larger than my budget. When things like bonus material, Czech subtitles and bizarre thirty-five year old films from the premiere party are important to me, I buy the DVD. When I just wanna see Bruce Willis kick ass just one more time, I'll copy the darn disc.
As for porn, the possibilities of piracy are endless. I have yet to come across and encrypted porn title. And they have multiangle shots, a lot of them!!! -
How many of you guys out there are using Macs with the Super Drive to rip DVD's?
No one has answered my question yet. Not trying to be rude Just would like some help.
Danny
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 18:04 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 16:03 -
New Mac user: Looking to rip, compress and burn DVD's on iMAC
By Jabroni4872 in forum MacReplies: 6Last Post: 12th Apr 2008, 21:53 -
How To Rip DVD and burn to Blu-Ray for archiving
By jntaylor63 in forum DVD RippingReplies: 0Last Post: 11th May 2007, 15:34
