I would like to purchase a certain PAL DVD and then back it up in such a way as it becomes an NTSC DVD. Is that possible? I have the backup apps and DVD2oneX, plus FCP4 and DVDSP2 (if that helps). Thanks for the info - good or bad.
The general consensus is yes, you can convert, and no, you probably don't want to. If you decide you want to, however, try MPEG2works. It has a nifty button to click, that should do everything for you. It might even keep your video in sync. Sacrifice something nice to the video gods, to make sure.
If it isn't broken, take it apart and find out why.
blog: deadsierra -
You would spend more than $30 of your time, and for which amount you can get a PAL/NTSC capable player at best buy.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
