Hello,
I have a Panasonic DMR 80, and want to Record simple copies of my family VHS home videos to DVD. Heres how I have things connected. I have the output of the VHS unit going into the DVD, using the back Input #3, and using RCA cables (2 audio, 1 video) as the VCR does not have S-Video. I set the input switch on the DVD, to input #3, (1 and 3 are on the back of the unit, 2 is in the front for Camcorder)and select the output as Output #1, and I see nothing. When I switch to Output 2, I see the VCR tape running on my monitor, so it seems it is getting signal into the DVD. I have the DVD Output #1 going to the input #1 of my RCA TV using RCA cables. Everything else works except for this...ie making DVD's from Direct TV box, dubbing to DVD -R, etc...
What am I doing wrong as I've spent hours trying to figure this out, and I thank anyone in advance for your help on this.
Jerry
Results 1 to 10 of 10
Ok I got the same unit and this is my setup I got the direct tv set to record input L1 ,when I want to record to my HDD I plug my vcr into the front rca jacks behind the little door on the left side of the unit (L2) and it works fine and finally I got the dvd output going to my HDTV monitor via the component video cables (red/green/blue) and the audio output in the same out put area. So this should take care of your problem
It is not possible ... so you might as well sell it to me ... I'll give you a $100 bucks for your DMR-E80.
or we can trade ... I'll send you my DMR-E50S for your DMR-E80
Sounds like a deal ... huh ???
Try the Video CopyMaster -- Model SED-CM
made by Sima ... $50 bucks at BestBuy
Works for me.
Oh yeah ... It wont work for copying DVDs ... only VHS video tapes.
Oh and maybe ... somewhere in the setup though your remote control is a option for turning on that input your having problems with.
My Mitsubishi Hi-Fi S-VHS VCR .... has an option in it for which input I want to use ... rear or front. -
Hi there
just a quick thought, its not related to recording RGB instead of composite is it, I know a number of recorders I have played with have recorded from RGB or Composite/Svideo but not both requiring changes in the menu before selecting a composite only input (such as VHS)
Best regards
Edz -
louthewiz,
I tried this and it works...This will solve the problem, but in the manual, which doesn't expand on things well, it clearly shows that you connect it
to either the back input on the DVD or the front. Does anyone know what the front connection has that the back one does not? I would think that a unit of this level would pretty much just be plug and play, but maybe not...
Thanks,
Jerry -
One other note...I see nothing in set-up that allows you to define the input signal type...
Jerry -
Well ... it was just a idea.Originally Posted by Hoopr
On my DMR-50 ... I have 3 VCRs sitting on a shelf
Stand by for picture
The DMR-E50S is on the bottom there ... the front input connections are coming from the Panasonic VCR [3rd vcr up from the bottom]
A real rats nest huh ?? ... I had to put labels on my wires going into the switch box ... sitting on bed with all the wires going into it.
Looks complicated but ... not really ... LOL
Oh and my couch ... it's very comfortable to sleep on. Since my bed is occupied. -
I was about to post that... "You don't sleep at all ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
OMG lacywest!! How do you move around in there??
And here i thought I had too many wires lying around
Panasonic DMR EH59 - Software to remove copy protection from sattelite TV
By bjuice in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2012, 12:50 -
copy VHS tapes to computer
By pfisher in forum Newbie / General discussionsReplies: 26Last Post: 27th Sep 2010, 18:49 -
VHS to DVD Help (panasonic dmr-ez48v)
By BrianJ844 in forum Newbie / General discussionsReplies: 14Last Post: 21st Jul 2010, 20:03 -
No video on Panasonic DMR-EZ47V DVD/VHS player
By orangeprs in forum Newbie / General discussionsReplies: 1Last Post: 12th Apr 2010, 16:42 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57
