I have tried unsuccessfully to convert a DIVX movie to MPEG2 (DVD).
Each time I encode (using TmpGenc) the sound is out of synch.
I have tried extracting the sound (WAV) file using VitualDub and then encoding to DVD (using TmpGenc by selecting the DIVX as input for video and the WAV file as input for the audio) but the sound was nowhere near being in synch on the output file.
I then selected the original DIVX file for input as BOTH video AND audio and while the sound appared to be in synch at the beginning is was out by maybe 2 seconds by the end of the output video.
Using GSPOT (to determine codecs on the original file) it shows that the STREAM TYPE is OpenDML AVI, the video codec is div3 DivX 3 Low-Motion with a bit rate of 825 kb/s and 23.976, and the audio codec is 0x0055(MP3) ID'd as MPEG-1 Layer 3 with a bit rate of 141 kb/s (70/ch, stereo) VBR LAME3.89 48000 Hz.
Should I try TooLame to extract the audio?
What is the answer to fix this synch problem?
John
convert the audio to 4800 mhz and save the file as wav using virtualdub. then convert the wave file to ac3 / 192 bitrate using ffemggui.
when you're converting the avi to mpeg2 are you setting the output frame rate to 23.97 with 3:2 pulldown encode mode?
use tmpgenc dvd author or other dvd authoring program to mux the video and audio. -
/Mats -
If the sync problem still exists after remuxing and buffing and waxing then you will have to either stretch or shrink the time line of the audio with a sound editor program so that it matches.,takes some work but can be done.
Originally Posted by jgarnold
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 17:12 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 05:48 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56 -
No sound when converting DVD (VIDEO_TS)
By jompa in forum ffmpegX general discussionReplies: 3Last Post: 18th Oct 2007, 16:48 -
No sound when converting FLZ file to AVI DivX!
By zanyjudy in forum ffmpegX general discussionReplies: 3Last Post: 14th Sep 2007, 06:02
