  1. The programs that came with Snazzi III USB2 are Movie Mill for capturing and InterVideo WinProducer 3 for editing.
    I have a question regarding the format that Movie Mill captures in when I choose DVD MPEG2 quality. After installing Movie Mill I can watch the captured file fine in Windows Media Player and Movie Mill itself, but it won't open in Adobe Premiere or InterVideo WinProducer 3 so I can edit it. Are there codecs I need to download in order for the MPEG2 files to be viewable with these programs?
    I would also like to add that the format I set Movie Mill to capture in is the same every time, but sometimes the MPEG2 file will open in WinProducer and sometimes it won't. It seems like something random is happening even though I do the exact same thing every time.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    Adobe Premiere does not edit mpeg2 files (very well or more often, not at all, depending on version) , plus mpeg is not really made for editing in the sense of video editing ...
  3. I'm really more concerned that I can't edit in WinProducer3 since that's the program that came with Snazzi specifically for editing the things that I capture. Sorry, I didn't really mean editing as in adding effects and such, I'm just taking out the commercials.
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi justified,
    I'm not familiar with "InterVideo WinProducer 3", so can't comment. However, I have seen quite a few people saying that they highly rate "Womble MPEG VCR" for MPEG editing.
    Failing that, capture in AVI (if you can) and use Adobe Premiere. Editing AVI is much easier and safer.
    Hope that helps...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  5. I'm giving Womble a try and it seems to be really fast but for some reason when I cut something the audio goes out of sync? Same with VirtualDub MPEG2. Also the output quality for VCD isn't that great.
  6. Member lgh529's Avatar
    Apr 2003
    Syracuse, Utah, USA
    Thats why you shouldn't edit MPEG2. It is very difficult, if not impossible to even do simple cuts and joins. Like others have said, capture in AVI, then convert to MPEG
  7. Member daamon's Avatar
    Melbourne, Oz
    @ justified,
    Weird. I've seen people reporting this problem when editing MPEG's with other tools, and have been recommended to use Womble. They (all, I think) came back with positive results.
    Have a search in the forums - it might be that you're missing something or it's something to do with the MPEG itself.
    I'd still recommend capturing in AVI over MPEG (have you tried? are you able?) if you're planning on editing (even simple cutting) - especially as it seems you've got Adobe Premiere. I use TMPGEnc to then encode to MPEG2 having exported DV AVI from Premiere.
    Good luck...
    Carpe diem.
  8. Banned
    Oct 2003
    Americas
    Vegas is very good with MPEG2. Whatever you edit....
