Hey all, well I'm running Panther and have followed all the steps I could find. I start the DVD with the macDVD player let it play for a few minutes etc. etc. However whenever I try to start DVDBackup it pop-ups in my dock for 1/2 sec then disappears. Has anyone ever come across this or can anyone give me any advice?
Thanks for any help!
Diesel
You can always try MacTheRipper . . . no need to play the DVD with DVD Player before ripping. Here's the thread.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
You are probably running Stuffit 8.0, which is buggy and doesn't unstuff executables with the right permissions. Update to Stuffit 8.02 and this problem should go away. Here is the link:
http://www.stuffit.com/mac/deluxe/updates.html -
While this may be the problem there are some people who updated to Stuffit 8.0.2 at the same time as udating to Panther (me for one) for whom DVDBackup no longer works. I just switched to 0sex (and now to MactheRipper as well
). Byebye DVDBackup.
You can eliminate a lot of the problems of DVDBackup under Panther if you simply leave Apple DVD Player running in the background while you rip your DVD. You don't have to actually play the DVD in the player application, just have the player running. You'll find this eliminates all this nonsense about having to play each chapter, etc.
My guess is that Apple changed the DVD drive authentication in the player application under Panther.
Mov to mp4 won't work
By Klagar in forum Video ConversionReplies: 1Last Post: 15th Dec 2010, 12:07 -
Why won't my mic work on my camcorer?
By apples017 in forum Capturing and VCRReplies: 3Last Post: 12th Jun 2008, 06:05 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 14:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 09:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
