Hi to all knowledgable forum dwellers! 8)
I am asking this question for a freind.
He is having a problem with his LG DVD-Writer.
This is his "version of events":
He can record to DVD-RW + or - with any of his burning programs including XP's burning utility. However, when he inserts a DVD-R (+ or -) to the writer,
and tries to do anything with the DVD via XP, windows gives an error message that the media is not correct, valid or simillar. To cut a long story short, XP can not explore or write to a DVD-R media. He tried three different media's and he is working with the latest firmware. The problem does not ocure with his other burning programs.
Any ideas? Is this a known problem? Are there known issues between XP's burning utility and DVD-R media?
Thanks for looking and thanks in advance if you have an answer.
Tzamroor.
I'm not exactly aware of -
please elaborate.XP's burning utility
And if the problem doesn't occur with the other burning programs...then why not just use the other burning programs? -
Windows XP built-in burning program will only do cd-r/cd-rw according to this Micros*ft website.
http://www.microsoft.com/windowsxp/expertzone/focuson/cdburning.asp
But use nero or another compatible burner with more features instead of that worthless BillGates Burner.....LOL
MMMMMMMMMMMMM..........sprinkles -
northcat_8 - XP burning utility - or otherwise known as (I think) CD writer wizard - simple "cut and paste" or "copy to...." which you can use with your writer. When you send an item to your cd-writer via Windows explorer and then ask windows to "Write these files to CD".
Windows xp might be needed for back-up (?) or when you simply want to write files to the DVD like you would with a CD Writer. However, come to think of it - Why ?
Like I said I am asking for a freind so I am not sure. For some reason it bugs him that XP has no problem with DVD-RW and can not handle blank DVD-R..... go figure
Redman66 - do I detecet a slight problem with Bill?
In any case, many thanks for your valued help!
I will pass your recomendations to my freind.
Other users feel free to leave feedback if you have another/different angle...
Tzamroor. -
I agree with Redmann. Use something else. Heck I wasn't even aware that there was a burning program in XP, I wouldn't use it anyway...microsoft is an OS software company...not a burning software company...go with a software that is from a company based on burning software, he'll be much happier and have fewer problems.
Go get Nero.
DVD recorder wont recognise disks
By ruthybear in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2010, 14:16 -
LG RH2T80 - won't recognise DVD's
By Dalene in forum DVD & Blu-ray RecordersReplies: 3Last Post: 17th Oct 2010, 00:34 -
DVDFab won't recognise DVD
By audax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 01:16 -
recognise whether a DVD is Shrinked or Untouched
By ppeterr in forum DVD RippingReplies: 10Last Post: 28th Dec 2009, 21:41 -
DVD will play in PIONEER Standalone but NOT Recognise in...........
By rockonvidtrade in forum Authoring (DVD)Replies: 1Last Post: 13th Apr 2009, 00:14
