I've determined that a DVD I wish to convert to SVCD is telecined. I will be watching the SVCD only on a regular interlaced TV (non-HD, non-progressive). Do I need to run an Inverse Telecine (IVTC) process or is that really only needed for proper display on a PC or progressive scan TV?
Thanks !!
Results 1 to 25 of 25
On a TV, I'd do it. Telecined material looks jerky on my TV when there is side to side movement (and top/bottom) but that's less noticeable.... I need to save off a small clip because I harp on this every time I see it. I'll make a note to do it this weekend...
For your situation, the main advantages would be better compression during encode, and 2 less frames out of every 5 to encode...
If you leave it as is, then that's okay too.. Since it was made to display originally for what you're viewing...
Good luck!! -
When it plays it will be telecined. You are asking for trouble
if you IVTC . -
Yeah, but Foo, if he runs Pulldown.exe on the .m2v file, I can't see there being a problem..
Whatddya think?? -
Waste of time when playing on tv. Plus IVTC is not perfect.
Originally Posted by fmctm1swWant my help? Ask here! (not via PM!)
I've seen quite a few videos that
are mixed 24 30 or have non uniform pulldown sequences.
and if you edit it , you are sure to disturb the sequence.
I've had enough problems to be wary of it.
If it's from a NTSC FILM video you don't have to IVTC anyway
it's already progressive , and can be re-encoded like that -
First off, I doubt that your DVD is hard telecined (why don't you tell us what the source is so we can confirm this).
Second, a properly telecined video looks normal on a TV. If not done properly, then it will look lousy. Remember that you have been watching telecined material all of your TV viewing life, and there is very seldom a complaint of "jerky" video. Anyway, fmctm1sw, you recommend that he IVTC his video because of "jerkiness". The last process that he will need to do is telecine the material again. You got it right, but for the wrong reasons.
Third, there is the opportunity for having higher bitrates (or less space needed) with a proper IVTC. But you encode 4 frames out of 5 (not 3 out of 5).
Fourth. Trouble from IVTC'ing? Not if it is done correctly. There are filters that will IVTC quite accurately.
Fifth. I can assure you that performing an IVTC is definitely worth the effort. Without the one extra frame out of every five, this action alone will allow you to encode at a bitrate about 20% higher than if you don't IVTC. Either that, or you can pack more video on your disc.
I sense a debate coming....
Sixth. Videos that the FOOmeister is refering to are called hybrids. These are by far the most difficult to IVTC. Fortunately, they are not that common (unless you are doing TV shows with CGI in them - like Star Trek TNG, or Enterprise). For most peoply, hybrids are better off left as hard telecined products.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by SLK001
I use VirtualDub to do the IVTC, and it's been working fine. I've run into other shows that have had a "hybrid" TC issue, but not Star Trek."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
I don't do these episodes, so I was just guessing about Enterprise. I have heard that ST-TNG is definitely a hybrid offering.
I imagine the these hybrids would even give the studios headaches.ICBM target coordinates:
Put me in the camp that suggests you try inverse telecining. It's well worth it. And it is not so hard. The 3:2 pattern rarely changes (unless you dropped a lot of frames while capturing).
I just recently wrote my own manual IVTC function in AVIsynth. It's easy to get synched with the pattern, easy to identify the pattern change points, and easy to correct for pattern changes. Chances are you will not have to correct for pattern changes more than you have breaks in the video such as disc changes or commercials (or dropped frames).
Give it a try. The benefits far outweigh the costs.
Darryl -
I've done some (less than a dozen) of TNG's episodes, as well as some DS9 episodes, and so far I haven't run in to any that are hybrids, but maybe I've just been lucky so far
Zefram Cochrane
2073 -
Instead of a completely blind IVTCing process in AVISynth, I recommend Donald Grath's DECOMB filter. If you use the "High Quality" modes of TELECIDE and DECIMATE, you can get near 100% accuracy.
I did a 130 minute movie from a laserdisk capture over the holidays and I have yet to find where the decisions made by this filter were incorrect.ICBM target coordinates:
Yeah, Decomb is great. I use it all the time. But I wrote my own function because of decomb's failure. It usually does a great job, but for some reason Star Wars confused it.
I'd be interested in checking out some Star Trek episodes. I've read before that they are hybrid, and it just seems stupid to me. I'd like to see it for myself. What would be the reason behind that? The CGI renders would take longer, you would have to edit video instead of film frames (which seems more difficult). I mean if you are hell bent on editing video instead of film, why not shoot the whole thing in video?
Darryl -
Originally Posted by SLK001"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Thanks for all of the replies. This has certainly become a very informative thread.
Here is some addtional info ...
The DVD is a Music Video -- Eagles: Hell Freezes Over. It appears to be a pattern of interlaced and non-interlaced as follows: PPP-II-PPP-II-PPP, etc. I assume that this is a telecined video that was originally FILM and is now NTSC.
Again -- my intent is to convert to SVCD and play on a standard NTSC/interlaced TV. -
That pattern is the standard 2:3 pulldown pattern for telecined material. For putting on an SVCD, I would IVTC it. This would buy me a higher bitrate.
I agree with SLK001 - IVTC whenever you can. It saves bitrate, or gives you more bitrate per sec, so you get a better picture....
If you're not comfortable with AVISynth, try VirtualDub to IVTC it - there is a good guide on this site about how to do it."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
If you play a telesinced MPEG file in a software DVD player (like PowerDVD), it will automatically de-interlace it, removing that "combing/flickering" effect you are seeing."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
A properly applied 2:3 pulldown will not result in the flickering that you noticed. The persistance of the TV's phosphor will ensure that it doesn't happen. Also, remember that the video also plays faster (each frame only plays for 33mS as opposed to 41mS). It could be the settings that you are using for your pulldown.
Also, the software players will not deinterlace the video, but they will remove the telecining (or just not apply a pulldown), and play the video at it's original 24fps frame rate. However, if your video is hard telecined, then it will be displayed "as-is", and at the display rate of 29.97fps.ICBM target coordinates:
Need help IVTC a video
By drawar in forum Video ConversionReplies: 16Last Post: 31st May 2011, 22:29 -
IVTC - could someone help?
By Gew in forum Newbie / General discussionsReplies: 51Last Post: 8th Feb 2010, 21:26 -
Why can IVTC not be perfect?
By loekverhees in forum Newbie / General discussionsReplies: 12Last Post: 31st Oct 2009, 17:51 -
ivtc help
By iamtehsux in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2008, 19:58 -
IVTC Help!!!
By Martig in forum Video ConversionReplies: 1Last Post: 11th Jan 2008, 01:43
