Hi Guys, (not sexually descriminatively aimed)
I have been using dvd decrypter for some time now, with a good degree of success and some speeds attaining 15.5x. But, today, it has decided that it was only going to reach 2.2x max. Any ideas why? I am using the latest version and have several other versions. I took out 3.1.6.0 and installed 3.1.9.0 No change. I have tried using my rom drive (pioneer) and writing drive (nec 2500) No different.
Any help would be appreciated
System:- athlon 2ghz 512 ddr 333mhz XP pro.
cheers,
sjtpepper
Nice attempt at bolding your subject line
No idea on DVD Decryptor though but I use the 'if it ain't broke, don't fix it' method -
If your source is scratched or etc. DVD Decrypter slows down, but... it realy reads it!
I had some problems with a DVD which doesn't works on my standalone player - very bad! But DVD Decrypter copied it to HDD (very slow, but with no errors). Big advantage of the program.
Try with other source! -
In addition to the above problem i have, i might add that the "time remaining" clock is flying up and down. I just started to decrypt "Bodyguard" which usually decrypts in under 5 mins, it is now telling me basically to come back tomorrow!!!
There is no strain on the processor, and space is not a problem.
Any Idea???
thanks
sjtpepper -
I had a problem with DVD Decrypter and DVD Shrink (ripping, analyzing, encoding) and tried DVD X Copy, which also had problems, where they all would take about 2x as long as they had previously. System Restore to a few days back fixed it.
Sounds like it got kicked back to PIO mode. Uninstall in Device Manager the IDE channel the drive is on, re-boot, Windows will re-install and all should be good.
JtommyJ[b]
I owe you a drink buddy!!
Success was mine after i removed the eide drivers and re-booted (twice) it then reached the dizzy heights of 11.9x and ripped bodyguard in 6 mins.
Why would the drivers become defective? and how would i know if i am in PIO mode or not? both my dvd drives are set to DMA.
thanks. -
XP has a tendency to do that, sometimes when adding a new program or just on its own. I use Windows Server 2003 so I'm not sure why but if it happens again, you now know how to fix it.
Coors Light, BTW.
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 14:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 14:11 -
DVD Decrypter from one pc to another
By jwedge in forum ComputerReplies: 3Last Post: 26th Jan 2008, 23:35 -
DVD Decrypter
By Beaker14 in forum Newbie / General discussionsReplies: 17Last Post: 26th Oct 2007, 22:39 -
I am using DVD Decrypter
By Lissettep in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 16:55
