hi can someone please tell what to do to burn a dvd ...i have a pioneer 106, and easy cd+dvd 6 software..and a dvd-rom...is there anything else that i need ?...can someone give me a step by step guide on how to use the software as this is a first for me regards theted.![]()
Ok you see the nicely coloured blocks to your left, if you click one of the green ones (the one that says Guides) and do something called reading you will infact find the answer to your question
hey, or u could go to www.dvdshrink.info and follow some really nice/easy step by step guides using dvdshrink, its a great program.
hope this helps, josh
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
