hey, i just encoded a movie to xvid in virtual dub, and i converted the ac3 to ogg, now i just need to mux them together....any ideas anyone?
thx, josh
You can use OGGmux to mux the avi and ogg together but that will create an OGM file. If you insist on using avi you're better of using Virtualdub to encode the audio to ogg using a wav input while using the xvid as the video source(direct stream copy).
ok, thx for the reply, i'll just make it in an ogm container, makes no difference to me :P
thx, josh
MUX Mp3 Into AVI
By onesikgypo in forum LinuxReplies: 4Last Post: 13th Apr 2010, 02:05 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 11:10 -
What will mux Divx video with OGG audio?
By bizzybody in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2009, 19:05 -
Turn .ogg into .avi
By babellou2 in forum ffmpegX general discussionReplies: 8Last Post: 22nd Jun 2007, 06:46 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 06:42
