Hi everyone
i'm currently trying to extract the audio to a .wav file with VirtualDub since the avi is encoded with vbr.
The problem i have is that after a few mintues it brings up the following error :
"ACM reported error on audio decompress (200)"
is there anything i can do to stop this since after this error is produced it stops extracting.
thanks for any help
Steve
thanks that actually worked perfectly. Unfortunately i now have a problem with the video.
Rather than make a new topic maybe you can help me again
Using the source range in tmpengc i'm making two files so it can go onto 2 vcds. But for some reason on the second one about half way through the video just goes black and leaves only the audio.
I've checked the original video and it works perfeclty all the way through it's just during the encoding that the video goes black
Don't suppose you can help me once more oh wise one -
/Mats
Problem extracting audio from mkv
By Djago in forum Video ConversionReplies: 5Last Post: 12th Jan 2012, 18:57 -
Problem extracting audio from WMV files
By Bully9 in forum AudioReplies: 33Last Post: 21st Jul 2011, 05:27 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
synching m2v and wav audio - strange problem
By ecc in forum EditingReplies: 7Last Post: 20th Feb 2008, 05:22 -
Audio problem with WAV files
By vertical in forum Newbie / General discussionsReplies: 5Last Post: 8th Jul 2007, 17:47
